MIG Posted April 3, 2014 Author Share Posted April 3, 2014 5TFUM5F12CX037212 Дайте и на мою, заранее благодарю! А вот)Division: TOYOTA Model: Tundra Grade: TUNDRA GRD Model Year: 2012Drive Type: 4WD Body Type: Extended Engine Family: V8 - 1UR-FE Transmission: 6ATDate of First Use: 08/28/2012 Production Date: 06/08/2012 Plant Code: X - SAN ANTONIO PLANT - TMMTXVIN: 5TF-UM5F1-2CX037212 Standard Equipment [-]EXTERIOR6.5' Double-Walled Bed w/ Rail CapsDaytime Running Lights (DRL)Easy Lower and Lift TailgateINTERIOR40/20/40 Split Fold-Down 8-Way Driver &4-Way Passenger Adj Front Bench SeatDual Zone Air ConditioningAM/FM CD w/ MP3/WMA, 6 Speakers,SXM Compat (HW & Subscr Req), Aux JackPower Windows/Door Locks/Heated MirrorsRemote Keyless Entry SystemTilt Steering Wheel with Column ShifterCruise Control, Engine ImmobilizerMECHANICAL & PERFORMANCE4.6L i-FORCE V8 DOHC 32V with DualIndependent VVT-i 310 hp / 327 lb-ft6-Spd Automatic Trans w/Sequential Shift4WDemand Part-Time 4WD w/Elec ControlledTransfer Case, A-TRAC & Auto LSDTripleTech Frame: Fully-Boxed Fr SectionReinforced C Under Cab, Open C Under Bed3.909 Rear Differential w/9.5" Ring GearInd Coil-Spring High-Mounted DoubleWishbone Front Susp w/ Stabilizer BarTrapezoidal Multi-Leaf Rear Suspensionw/ Staggered Outboard Mounted ShocksPower-Assisted 4 Wheel Disc Brakes18" Styld Stl Wheels w/ P255/70R18 TiresSAFETY & CONVENIENCEStar Safety System: Vehicle StabilityControl (VSC), Traction Control (TRAC),Anti-Lock Brake System (ABS) withElectronic Brake Force Distribution(EBD), Brake Assist (BA), & SmartStop Technology (SST)Trailer-Sway ControlDr & Fr Pass Advanced Airbag SystemDr & Fr Pass Seat Side & Knee AirbagsRoll-Sensing Curtain Airbags (RSCA)3-Point Seatbelts for All Positions withDriver ELR & ALR/ELR for All PassengersTire Pressure Monitor System (TPMS)Exterior Color: 08S6, NAUTICAL BLUE METALLIC Interior Color: **13, GRAPHITEInterior Trim Color: **, * Interior Fabric: *, *Accessories:2Q : All Weather Mats CP : Convenience Package: EV : AM/FM CD Player FE : 50 State Emissions LU : Bedliner w/out Deck Rail System TO : Tow Package: Quote Link to comment Share on other sites More sharing options...
max_123 Posted May 14, 2014 Share Posted May 14, 2014 здравствуйте а мою 5tfbv54108x053813 Quote Link to comment Share on other sites More sharing options...
MIG Posted May 15, 2014 Author Share Posted May 15, 2014 здравствуйте а мою 5tfbv54108x053813 Пожалуйста) Division: TOYOTA Model: Tundra Grade: SR5 Model Year: 2008Drive Type: 4WD Body Type: Double Cab Engine Family: Large V8 - 3UR-FE Transmission: 6ATDate of First Use: 01/05/2009 Production Date: 01/31/2008 Plant Code: X - SAN ANTONIO PLANT - TMMTXVIN: 5TF-BV541-08X053813 Standard Equipment [-]INTERIORCloth Buckets w/8-way Pwr Adj Drvr-sideTilt/Telescoping Steering WheelDual Zone Climate Control w/Sync ModeAM/FM/6-CD w/6 Speakers & Aux Audio JackCenter Console w/Laptop & File StoragePower Windows/Door Locks/MirrorsRemote Keyless Entry SystemSAFETYSTAR Safety: Pwr Assist 4 Wheel Disc ABSw/Electronic Brakeforce Distrib (EBD),Brake Assist, Vehicle Stability Controlwith Active Traction Control (VSC+ATRAC)Dr & Fr Pass Advanced Airbags/Seat SideAirbags/3 pt Seatbelts w/Pretensioners& Force LimitersRoll-Sensing Curtain Airbags (RSCA)Tire Pressure Monitoring SystemMECHANICAL & PERFORMANCEGVWR = 7100 lbs. Payload = 1580 lbs.381HP/401 Lb-Ft 5.7L DOHC 32V iForce V8w/Dual Independent VVT-I and ACIS6-Spd Auto w/Seq Shift and Tow/Haul ModeEngine Immobilizer, Cruise Control4WDemand 4x4 System w/ElectronicallyControlled 2 Speed Transfer CaseTow Equip/Capacity (Except when equippedw/Sport Appr Pkg): Tow Cap = 10,300 lbs.Hitch Receiver, Supp A/T Cooler, 4.30Rear Diff w/10.5" Ring Gear, 150AAlternator, A/T Temp Gauge, 7 Pin Conn,Trailer Brake Controller PrewireAutomatic Limited Slip Diff (Auto LSD)TripleTech Frame: Fully-boxed Fr SectionReinforced C Under Cab, Open C Under BedCoil Over Shock Double A-Arm Front SuspMulti-Leaf Trapezoidal Rear Suspension18" Styled Steel Wheels P255/70R18 TiresPwr 4 Wheel Disc Brakes, 13.9" Fr RotorsEXTERIOR6.5' Double-Walled Bed w/Tailgate AssistBlack Handles, Pwr Htd Outside MirrorsChrome Grille Surround, Fr & Rr BumpersExterior Color: 01D6, SILVER SKY METALLIC Interior Color: **13, GRAPHITEInterior Trim Color: **, * Interior Fabric: *, *Accessories:AA : 18" Alloy Wheels w/P275/65R18 Tires C4 : Carpet Floor Mats - 4 piece FE : 50 State Emissions HM : Heated Mirror SP : SR5 Package WR : Sliding Rear Window w/Privacy GlassCampaign Description: Limited Service Campaign BST - 4Runner, Tundra Smart Stop TechnologyCompletion Status: Not CompletedCampaign Description: Safety Recall C0M Remedy Notice - Multiple Models and Model Years - Power Window Master Switch (PWMS)Completion Status: Not CompletedCampaign Description: Safety (Non-Compliance) Recall B0B - Certain 2008 through 2011 Model Year Land Cruiser, Sequoia, Tacoma and Tundra Vehicles Equipped with Toyota-Recommended Light Truck tires and TRD Accessory WheelCompletion Status: Not CompletedCampaign Description: Safety Recall A0A - Accelerator Pedal Reinforcement Bar InstallationCompletion Status: CompletedDate Serviced: 05/12/10Dealer Name: THOUSAND OAKS TOYOTADealer Code: 04167Campaign Description: Safety Recall 90L - Potential Floor Mat Interference with Accelerator PedalCompletion Status: CompletedDate Serviced: 05/12/10Dealer Name: THOUSAND OAKS TOYOTADealer Code: 04167 Quote Link to comment Share on other sites More sharing options...
max_123 Posted May 15, 2014 Share Posted May 15, 2014 спасибо! Quote Link to comment Share on other sites More sharing options...
Groovy Posted May 18, 2014 Share Posted May 18, 2014 Добрый день!расшифруйте крюшку плиз 5TFDW5F12AX133221 Quote Link to comment Share on other sites More sharing options...
MIG Posted May 18, 2014 Author Share Posted May 18, 2014 Добрый день!расшифруйте крюшку плиз 5TFDW5F12AX133221 по утру) Quote Link to comment Share on other sites More sharing options...
MIG Posted May 19, 2014 Author Share Posted May 19, 2014 Добрый день! расшифруйте крюшку плиз 5TFDW5F12AX133221 Division: TOYOTA Model: Tundra Grade: TUNDRA GRD Model Year: 2010 Drive Type: 4WD Body Type: Crew Max Engine Family: Large V8 - 3UR-FBE Transmission: 6AT Date of First Use: 03/17/2010 Production Date: 02/25/2010 Plant Code: X - SAN ANTONIO PLANT - TMMTX VIN: 5TF-DW5F1-2AX133221 Standard Equipment [-] EXTERIOR Double-Walled Bed w/Tailgate Assist Front Tow Hook, Engine Skid Plate INTERIOR 40/20/40 Front Bench Seat w/8-way Dr & 4-Way Fr Pass Adj, Center 3pt Seatbelts Dual Zone Climate Control w/Sync Mode AM/FM/MP3/CD w/6 Speakers & Aux Input Tilt Steering Wheel Power Windows/Door Locks/Mirrors Cloth Trimmed Seats Remote Keyless Entry System Variable Intermittent Windshield Wipers Manual Headlamp Adjust MECHANICAL & PERFORMANCE 5.7L iFORCE V8 DOHC 32V Dual Independent VVT-i 381HP/401 lb-ft, ACIS, Flex Fuel 6-Spd Automatic Trans w/Sequential Shift 4WDemand 4x4 System w/Electronically Controlled 2 Speed Transfer Case GVWR = 7200 lbs. Payload = 1575 lbs. Max Tow Cap = 8100 lbs. Engine Immobilizer, Cruise Control TripleTech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed 4.10 Rear Differential w/10.5" Ring Gear Automatic Limited Slip Diff (Auto LSD) Coil Over Shock Double A-Arm Front Susp Multi-Leaf Trapezoidal Rear Suspension Pwr 4 Wheel Disc Brakes, 13.9" Fr Rotors 18" Steel w/P255/70R18 SAFETY STAR Safety: Pwr Assist 4 Wheel Disc ABS w/Electronic Brake-force Distrib (EBD), Brake Assist, Vehicle Stability Control with Active Traction Control (VSC+ATRAC) Dr & Fr Pass Advanced Airbags/Seat Side Airbags/3 pt Seatbelts w/Pretensioners & Force Limiters Dr & Fr Pass Knee Airbags Roll-Sensing Curtain Airbags (RSCA) Tire Pressure Monitoring System Exterior Color: 01F9, SLATE METALLIC Interior Color: **13, GRAPHITE Interior Trim Color: **, * Interior Fabric: *, * Accessories: CK : Cold Weather Package: EV : AM/FM/MP3 CD, HM : Power Heated Outside Mirrors LF : Fog Lamps PE : Cloth Bucket Seats with Power RE : Federal Emissions RL : Daytime Running Lamps SP : SR5 Package: ST : 18" Styled Steel Wheel Campaign Description: Limited Service Campaign BST - 4Runner, Tundra Smart Stop Technology Completion Status: Not Completed Campaign Description: Safety (Non-Compliance) Recall B0B - Certain 2008 through 2011 Model Year Land Cruiser, Sequoia, Tacoma and Tundra Vehicles Equipped with Toyota-Recommended Light Truck tires and TRD Accessory Wheel Completion Status: Completed Date Serviced: 08/09/11 Dealer Name: JANZEN TOYOTA Dealer Code: 35052 Campaign Description: Safety Recall 90L - Potential Floor Mat Interference with Accelerator Pedal Completion Status: Completed Date Serviced: 04/22/10 Dealer Name: JANZEN TOYOTA Dealer Code: 35052 а вот пожалуйста) Quote Link to comment Share on other sites More sharing options...
Groovy Posted May 22, 2014 Share Posted May 22, 2014 а вот пожалуйста)А вот спасибо большое 1 Quote Link to comment Share on other sites More sharing options...
SPart Posted May 23, 2014 Share Posted May 23, 2014 День добрый Михаил и мою тогда до кучи 5TFHW5F12AX095555 Quote Link to comment Share on other sites More sharing options...
MIG Posted May 24, 2014 Author Share Posted May 24, 2014 День добрый Михаил и мою тогда до кучи 5TFHW5F12AX095555 как до компа доберусь) Quote Link to comment Share on other sites More sharing options...
MIG Posted May 26, 2014 Author Share Posted May 26, 2014 День добрый Михаил и мою тогда до кучи 5TFHW5F12AX095555 Division: TOYOTA Model: Tundra Grade: LIMITED Model Year: 2010 Drive Type: 4WD Body Type: Crew Max Engine Family: Large V8 - 3UR-FBE Transmission: 6AT Date of First Use: 06/25/2009 Production Date: 05/04/2009 Plant Code: X - SAN ANTONIO PLANT - TMMTX VIN: 5TF-HW5F1-2AX095555 Standard Equipment [-] EXTERIOR Cargo Bed, T/gate Assist, Deck Rail Sys Pwr Vertical Rr Window w/Privacy Glass Front Tow Hook, Engine Skid Plate INTERIOR Leather Trim Pwr Heated Front Buckets Slide and Recline 60/40 Rear Bench Seat Automatic Dual Zone Climate Control JBL AM/FM/MP3 6-Disc CD Chgr, 12 Spkrs, Aux/USB Input, Sat Radio 90-Day Trial, Steering Wheel Audio Cntrls, Bluetooth Power Windows/Door Locks/Mirrors Remote Keyless & Anti-Theft Alarm System Manual Headlamp Adjust MECHANICAL & PERFORMANCE 5.7L iFORCE V8 DOHC 32V Dual Independent VVT-i 381HP/401 lb-ft, ACIS, Flex Fuel 6-Spd Auto w/Seq Shift and Tow/Haul Mode 4WDemand 4x4 System w/Electronically Controlled 2 Speed Transfer Case GVWR = 7200 lbs. Payload = 1555 lbs. Tow Equip/Capacity: Tow Cap=10,100 lbs. Hitch Receiver, Supp A/T Cooler, 4.30 Rear Diff w/10.5" Ring Gear, 150A Alternator, A/T Temp Gauge, 7 Pin Conn, Trailer Brake Controller Prewire Engine Immobilizer, Cruise Control TripleTech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed Automatic Limited Slip Diff (Auto LSD) Front and Rear Sonar Coil Over Shock Double A-Arm Front Susp Multi-Leaf Trapezoidal Rear Suspension 18" Alloy w/P275/65R18 SAFETY STAR Safety: 4 Wheel Disc ABS w/Elec Brake-force Distrib, Brake Asst, Veh Stability Cntrl w/Active Traction Cntrl Dr & Fr Pass Advanced Airbags/Seat Side Airbags/3 pt Seatbelts w/Pretensioners & Frc Limiters, Dr & Fr Pass Knee Airbags Roll-Sensing Curtain Airbags (RSCA) Tire Pressure Monitoring System Exterior Color: 03Q3, SALSA RED PEARL Interior Color: **13, GRAPHITE Interior Trim Color: **, * Interior Fabric: *, * Accessories: 48 : Platinum Door Sills - FSA I3 : PLATINUM PACKAGE PT : Platinum Package: RE : Federal Emissions Service Campaign Campaign Description: Limited Service Campaign BST - 4Runner, Tundra Smart Stop Technology Completion Status: Not Completed Campaign Description: Safety (Non-Compliance) Recall B0B - Certain 2008 through 2011 Model Year Land Cruiser, Sequoia, Tacoma and Tundra Vehicles Equipped with Toyota-Recommended Light Truck tires and TRD Accessory Wheel Completion Status: Not Completed Campaign Description: Safety Recall 90L - Potential Floor Mat Interference with Accelerator Pedal Completion Status: Completed Date Serviced: 11/12/10 Dealer Name: FORT BEND TOYOTA Dealer Code: 42273 Campaign Description: Safety Recall A0A - Accelerator Pedal Reinforcement Bar Installation Completion Status: Completed Date Serviced: 03/12/10 Dealer Name: FORT BEND TOYOTA Dealer Code: 42273 1 Quote Link to comment Share on other sites More sharing options...
SPart Posted June 8, 2014 Share Posted June 8, 2014 (edited) тоже еле до компа добрался, спасибище огромное Михаил. работы мама не горюй,тока приехал вот сейчас...03.50 местного.. Edited June 8, 2014 by SPart 1 Quote Link to comment Share on other sites More sharing options...
Tundrik Posted August 21, 2014 Share Posted August 21, 2014 Тоже интересно стало. Будьте добры 5TFUY5F11AX134211 Quote Link to comment Share on other sites More sharing options...
MIG Posted August 28, 2014 Author Share Posted August 28, 2014 Тоже интересно стало. Будьте добры 5TFUY5F11AX134211 к понедельнику постараюсь) Quote Link to comment Share on other sites More sharing options...
Константин83 Posted August 28, 2014 Share Posted August 28, 2014 5TFBW54189X088663 пожалуйста Quote Link to comment Share on other sites More sharing options...
Tundrik Posted August 28, 2014 Share Posted August 28, 2014 к понедельнику постараюсь)спасибо. Буду ждать Quote Link to comment Share on other sites More sharing options...
MAG Posted August 30, 2014 Share Posted August 30, 2014 5TFUW5F12AX101482Приветствую и респектую тундроводов! никак не разберусь с комплектацией своей тундрочки ,надеюсь на помощь! спасибо Quote Link to comment Share on other sites More sharing options...
Prospect Sergey Shtirlits Posted August 30, 2014 Prospect Share Posted August 30, 2014 И Вам привет, а где фото и запись в бортовом журнале? Quote Link to comment Share on other sites More sharing options...
Игорь Каменск Posted August 31, 2014 Share Posted August 31, 2014 5TFUW5F12AX101482Приветствую и респектую тундроводов! никак не разберусь с комплектацией своей тундрочки ,надеюсь на помощь! спасибо SR5 Quote Link to comment Share on other sites More sharing options...
MAG Posted August 31, 2014 Share Posted August 31, 2014 SR5привет! на кузове есть логотип "трд" а вот на амортах я не нахожу шильдик "бельштейн",в комплектации SR5 идут противотуманки ,а у меня заглушки ,вообщем запутался хотелось бы узнать по вин коду подробнее. Quote Link to comment Share on other sites More sharing options...
Игорь Каменск Posted August 31, 2014 Share Posted August 31, 2014 привет! на кузове есть логотип "трд" а вот на амортах я не нахожу шильдик "бельштейн",в комплектации SR5 идут противотуманки ,а у меня заглушки ,вообщем запутался хотелось бы узнать по вин коду подробнее.Привет! Трд это не комплектация, это просто доп. пакет, так же как буксировочный например. Что точно под этим вином вышло с завода, Миша может подсказать, у него хитрая выяснялка какая-то есть, ждем.) Quote Link to comment Share on other sites More sharing options...
MIG Posted August 31, 2014 Author Share Posted August 31, 2014 привет! на кузове есть логотип "трд" а вот на амортах я не нахожу шильдик "бельштейн",в комплектации SR5 идут противотуманки ,а у меня заглушки ,вообщем запутался хотелось бы узнать по вин коду подробнее. логотип TRD с чем? спорт или оффроуд или рокварриор? Амморты какого цвета? Обычно туманки не идут у рокварриора в комплекте 1 Quote Link to comment Share on other sites More sharing options...
MAG Posted September 1, 2014 Share Posted September 1, 2014 привет! на кузове есть логотип "трд" а вот на амортах я не нахожу шильдик "бельштейн",в комплектации SR5 идут противотуманки ,а у меня заглушки ,вообщем запутался хотелось бы узнать по вин коду подробнее.Cпасибо Игорь ,не знал ,пересел из субурбана ,пытаюсь хоть как-то разобраться . Quote Link to comment Share on other sites More sharing options...
MAG Posted September 1, 2014 Share Posted September 1, 2014 логотип TRD с чем? спорт или оффроуд или рокварриор? Амморты какого цвета? Обычно туманки не идут у рокварриора в комплекте с ор роад,но блин у меня сомнения ,наклеить можно что угодно ) аморты черного ,хотелось бы по вин коду ,Миш ) Quote Link to comment Share on other sites More sharing options...
Alex27Rus Posted September 10, 2014 Share Posted September 10, 2014 Комплектацию этой глянуть можно? 5tfhw5f19ax121486.Спасибо Quote Link to comment Share on other sites More sharing options...
