MIG Posted May 30, 2014 Share Posted May 30, 2014 Набрел тут вот на такую интересную штуку - радио в цифре без помех, не считая всяких доп ништяков типа управления iphon/ipad/ipod получается замена XM (спутнику в наших магнитолах) все же есть) FEATURESIn-car digital radio and audio adapterDual digital radio tuners supporting DAB/DAB+/DMBRBand III and L-Band supportDetachable controller with white high contrast OELD display5 illumination colours for controller buttons (blue/green/red/amber/white)Auto-Dimmer functionConnection for iPod/iPhone/iPad (Standard Apple cable required) and USB with full music control and chargingPause and rewind live digital radioAUX input, Line output, USB upgradeable, 30 presetsEasy connection to the car radio (Line out, wired and unwired FM Transmitter)DAB antenna optional (KAE-225DA / KAE-220DA)Full Apple connectivity, delivering media control from EZi-DAB (the USB port works with your standard Apple cable and is Works with iPod, iPhone and iPad compliant with full music control of these devices from the EZi-DAB controller)Great media connectivity – playback from USB thumb drives etc.Dual digital radio tuners provide a constantly updating dynamic station list – EZi-DAB adds new content and removes ‘dead’ stations as you move from one area to another across the countryCompact, dash-mounted detachable controller for reduced in-car clutterEZi-DAB has an OELD display with fantastic contrast making it easy-to-read from any angle and at nightOptional active film antenna for best reception (KAE-225DA / KAE-220DA)Easy installation – the interface box can be discretely installed in the most suitable location for the vehicle (behind the glove box, under the front passenger seat, etc.) and is powered directly from the car-wiring loom with a neat cabling solution. Extension cables can be run to accessible places so you can have access to USB and AUX connectivity for iPods, thumb drives, etc. and for software updatesFlexibility of installation – multiple ways of interfacing with your car radio: line out, FM transmit and FM transmit direct inject (no crackle)Easy software updates via USBForecourt pause:Forecourt pause helps you take control of your audio content and not miss a thing – even when you’re listening to digital radio – and has been designed for instances when you need to leave your vehicle and return again in a relatively short space of time, such as when you are visiting a petrol station or cash point. How does it work? When you take the keys out of your vehicle EZi-DAB will still receive power for around 15 minutes. In that period it sits in a “suspended” state (display off), meaning it is powered up but not actually playing any audio (this is best thought of as being like a low power mode: it won’t drain the battery). When you return to your vehicle and restart the ignition (within the 15 minute window), EZi-DAB will immediately switch back on and start playing again in one of the following ways:If you were listening to an iPod track it will resume where it left off (the point when you last heard audio).If you were listening to a digital radio station it will start to play live radio again.You can also pause the digital radio broadcast for up to 8 minutes, so you can fill up with fuel, go and pay, get back in the car and continue listening where you left off.Picnic mode:Picnic mode is perfect for when you have parked in an idyllic country spot and want a bite to eat outside but within range of your vehicle and would like to have some background music. So with the ignition turned off and the keys removed, you throw open the doors and turn EZi-DAB back on and listen to whatever you want to. After an hour EZi-DAB will automatically shut down ensuring that you never drain the battery on your vehicle.Note: both forecourt pause and picnic mode are subject to different vehicle specifications. For example some vehicles will only supply power to the main car stereo for 15 minutes with the ignition off and the keys out.SPECIFICATIONSController:Controls: Backlit buttons including rewind and fast forward transport controls, play / pause, back, home and favourites. Rotary dial with push select.Display: High contrast white-on-black graphical OELD display.Display mode examples: Full screen station name, name and scrolling text, reception information.Interface box / Tuner info:Frequency ranges: Digital radio Band III 174–240 MHz, L-Band 1452–1490 MHz and FM 87.5-108 MHzDigital radio tuners: x 2Input connectors:Digital radio antenna in: FAKRA SMBA connectorFM antenna in: ISO connectorAnalogue AUX IN: 3.5mm auxiliary inputPower supply: 8 way latched Molex connection - 12V taken directly from the vehicles wiring loomUSB: (type A) USB connection for iPod, iPad, iPhone, external hard drives and USB sticks for audio playback, also used for firmware upgrade via USB stickiPod & iPhone support:2nd, 3rd, 4th, 5th and 6th generation iPod NanoiPod Touch 1st, 2nd, 3rd and 4th generationiPhone 2G, 3G, 3Gs, 4iPad, iPad 2Output connectors:FM antenna out: ISO connector for pass-through of FM connectionAnalogue line out: 3.5mm headphone outputController connection: 6 way latched Molex connection to micro USBhttp://www.alpine.co.uk/p/Products/dab3842/ezi-dab на ebay http://www.ebay.com/itm/ALPINE-EZI-DAB-In-Car-Vehicle-Radio-CD-Player-Music-Audio-Headunit-Stereo-/121346828082?pt=UK_In_Car_Technology&hash=item1c40d5a732 Link to comment Share on other sites More sharing options...
Игорь Каменск Posted May 30, 2014 Share Posted May 30, 2014 Так баще если чо, Миша? Иван нарыл, за велописедом в гараже.) Link to comment Share on other sites More sharing options...
MIG Posted May 31, 2014 Author Share Posted May 31, 2014 Так баще если чо, Миша? Иван нарыл, за велописедом в гараже.) не) то через инет, а то что я выложил выше это цифровое - типа спутникового - в штатах я к нему привык, очень качество хорошее) И тематических каналов дофига - в отличии от эфирного радио Link to comment Share on other sites More sharing options...
Prospect SherrBob Posted June 3, 2014 Prospect Share Posted June 3, 2014 ну начал тему - развивай! интересно же Link to comment Share on other sites More sharing options...
Tundra330 Posted June 3, 2014 Share Posted June 3, 2014 не) то через инет, а то что я выложил выше это цифровое - типа спутникового - в штатах я к нему привык, очень качество хорошее) И тематических каналов дофига - в отличии от эфирного радиоУ нас нет же спутникового радио или я ошибаюсь ?Tundra 330 Link to comment Share on other sites More sharing options...
MIG Posted June 3, 2014 Author Share Posted June 3, 2014 У нас нет же спутникового радио или я ошибаюсь ?Tundra 330 спутника нет) а цифра есть! Link to comment Share on other sites More sharing options...
MIG Posted June 3, 2014 Author Share Posted June 3, 2014 ну начал тему - развивай! интересно же надо брать) на днях попробую на горбушку сгонять, полюбому у них что то подобное есть Link to comment Share on other sites More sharing options...
Fedoseev Posted June 3, 2014 Share Posted June 3, 2014 А чем интернет радио не устраивает? У меня например PCradio, отличная вещь. Link to comment Share on other sites More sharing options...
MIG Posted June 3, 2014 Author Share Posted June 3, 2014 А чем интернет радио не устраивает? У меня например PCradio, отличная вещь.ну интернет не везде есть) Link to comment Share on other sites More sharing options...
Fedoseev Posted June 3, 2014 Share Posted June 3, 2014 ну интернет не везде есть)Это где например у Вас нет инета? Link to comment Share on other sites More sharing options...
Prospect SherrBob Posted June 3, 2014 Prospect Share Posted June 3, 2014 ну я вот, например, по трассе еду и буду огрызки слушать? не, иногда хочется ведь радио слушать а не записи Link to comment Share on other sites More sharing options...
Fedoseev Posted June 3, 2014 Share Posted June 3, 2014 ну я вот, например, по трассе еду и буду огрызки слушать? не, иногда хочется ведь радио слушать а не записи Почему в записи, такая же онлайн трансляция. Link to comment Share on other sites More sharing options...
MIG Posted June 3, 2014 Author Share Posted June 3, 2014 Это где например у Вас нет инета? не поверишь) практически везде))) то есть он есть... но как бы не стабилен Link to comment Share on other sites More sharing options...
MIG Posted June 3, 2014 Author Share Posted June 3, 2014 А чем интернет радио не устраивает? У меня например PCradio, отличная вещь.а ссылку кинь на свой девайс? Link to comment Share on other sites More sharing options...
Fedoseev Posted June 3, 2014 Share Posted June 3, 2014 а ссылку кинь на свой девайс?https://itunes.apple.com/us/app/pcradio/id687195932?mt=8&ign-mpt=uo%3D4 https://play.google.com/store/apps/details?id=com.maxxt.pcradio Link to comment Share on other sites More sharing options...
MIG Posted June 3, 2014 Author Share Posted June 3, 2014 https://itunes.apple.com/us/app/pcradio/id687195932?mt=8&ign-mpt=uo%3D4 https://play.google.com/store/apps/details?id=com.maxxt.pcradio "Вы можете слушать радио в дороге, на даче, в машине, в парке и везде где есть мобильный интернет - EDGE, 2G, 3G, 4G, Yota, Wi-Fi." Вот! А радио хочется слушать и там где его нет) А нет его почти везде - даже Edge Link to comment Share on other sites More sharing options...
Fedoseev Posted June 3, 2014 Share Posted June 3, 2014 У нас наоборот с цифровым вещанием туго, а вот инет есть почти везде. А где нет инета, там и цифрового вещания подавно нет.https://buryatia.megafon.ru/help/zone/coverage/ Link to comment Share on other sites More sharing options...
MIG Posted June 3, 2014 Author Share Posted June 3, 2014 У нас наоборот с цифровым вещанием туго, а вот инет есть почти везде. А где нет инета, там и цифрового вещания подавно нет. https://buryatia.megafon.ru/help/zone/coverage/найти бы карту покрытия цифрового вещания - оно с сотовой связью никак не связано) Link to comment Share on other sites More sharing options...
Kok Posted June 3, 2014 Share Posted June 3, 2014 Надо тады в Эстонию перебираться. Единственная страна в мире, с практически 100% покрытием wifi! Link to comment Share on other sites More sharing options...
Fedoseev Posted June 3, 2014 Share Posted June 3, 2014 найти бы карту покрытия цифрового вещания - оно с сотовой связью никак не связано)Понятно, что не связано, но базовых станций у мегафона почти на каждом пригорке, а цифровых очень мало. В нашем городе в цифровом формате вещают 8 федеральных каналов и 3 радио, за пределами населенных пунктов вообще глухо. Link to comment Share on other sites More sharing options...
Dadets Posted June 4, 2014 Share Posted June 4, 2014 http://www.telesputnik.ru/archive/98/article/38.htmlhttp://www.tvtower.ru/dvbtv/moscow/Да и не забудь поставить на крышу спутниковую активную антенну . Они есть для использования на поездах и быстро настраиваются на сигнал или в судовом варианте. ........ Тундра машина большая место найдётся. Link to comment Share on other sites More sharing options...
MIG Posted June 4, 2014 Author Share Posted June 4, 2014 http://www.telesputnik.ru/archive/98/article/38.htmlhttp://www.tvtower.ru/dvbtv/moscow/Да и не забудь поставить на крышу спутниковую активную антенну . Они есть для использования на поездах и быстро настраиваются на сигнал или в судовом варианте. ........ Тундра машина большая место найдётся. там антенна в комплекте) ставится под стекло если я правильно понял, но можно и блинчик на крышу поставить) Link to comment Share on other sites More sharing options...
MIG Posted June 4, 2014 Author Share Posted June 4, 2014 Но учитывая где мы живем, скорее всего нужно будет что то типа Link to comment Share on other sites More sharing options...
Игорь Каменск Posted June 4, 2014 Share Posted June 4, 2014 Но учитывая где мы живем, скорее всего нужно будет что то типа Плюсы тоже есть, можно плов приготовить пока телик не смотришь..)) Link to comment Share on other sites More sharing options...
Dadets Posted June 6, 2014 Share Posted June 6, 2014 Плюсы тоже есть, можно плов приготовить пока телик не смотришь..))В судовом исполнении она выглядит как шар. А за одно всегда нырнет будет ( правда в одну сторону). Link to comment Share on other sites More sharing options...
