Оборудуем кузов - перевоз длинномеров, палаток, и прочего
http://www.tracrac.com
куча всяких рак в кузов и на крышу как кунга так и основную - однозначный must have) Из плюсов - не колхоз, легко снимаются и хранятся, из минусов - не силовые (но это сложно сказать на сколько минус).
post-4-0-17267900-1422086530_thumb.jpgpost-4-0-05918000-1422086531_thumb.jpgpost-4-0-98469300-1422086531_thumb.jpgpost-4-0-76401500-1422086532_thumb.jpgpost-4-0-76634900-1422086533_thumb.jpg
А самая навернутая тянет под 500 кг кстати.
http://www.tracrac.com/pick-up-trucks/tracrac-g2
Overview & Features
TracRac® SR is the newest generation of our original aluminum sliding truck rack system designed to help you get the most out of your truck. Our best truck rack system is designed to help you carry ladders, lumber, kayaks, canoes and anything else you can think of safely and securely. Easy installation and durable powder coating make this the most functional and best-looking truck rack system on the market. With optional accessories to carry anything you need to work hard and play hard, TracRac® is a valuable investment that is sure to last you through the life of your truck….and your next truck…and your next truck!
Features:
  • 1,250 lb Load Capacity*
  • Aerodynamic and Quiet (Features Wind Deflectors to reduce noise)
  • Easy to Install with Preassembled Components
  • Increased Rack Stability with Corner Brace Design
  • Lightweight (80lbs)
  • No Rust Aluminum Construction with Durable Powder Coating to Resist Wear
  • Damage Free Installation (No Drilling into Truck Bed)
  • Sliding Racks Adjust Along Full Length of Bed to Carry Different Loads and Can Easily Be Removed When Needed
  • Aluminum HD Load Stops/Tie Downs Adjust Across Full Width of Truck
  • Aluminum Side Cleats
  • Aluminum Crossbar Endcaps
  • Utilizes TracRac’s Patent Pending Modular Design Platform to Give Added Flexibility When Carrying Our Product Over to a New Truck or Replacing Damaged Components
Included Items:
  • 2 Black anodized aluminum (Base Rails Sold Separately)
  • 4 Expansion Block Stake Pocket Mounts
  • Front and Rear Powder Coated Aluminum Racks
  • 4 Quick Release Clamping Knobs
  • 4 Sliding Aluminum Load Stop/Tie Downs with Quick Release Clamping Knobs
  • 4 Aluminum ARC Side Cleats
  • 4 Aluminum Corner Braces
TracRac® Exclusive Optional Accessories:
  • Cantilever Extension – Adds Over the Cab Protection for Long Loads
  • Locking Security TracKnobs – Theft Prevention for Your TracRac®
  • Base Rail Tiedowns – Adjustable Equipment Tiedowns
  • Universal Truck Box Mount – Allows Mounting of Other Truck Boxes
http://www.tracrac.com/pick-up-trucks/caprac
А вот рейлинги на кунг
Overview & Features
Designed and built with the same high quality materials as all of our other TracRac products, the CapRac™ is the ideal solution for your truck cap or shell.  Whether you are carrying building materials to a job site or kayaks to your camp site, this lightweight, easy to install, aerodynamic rack will help you get the most out of your truck.   Dual concealed fasteners, ZEMAC powder coated swivel bases and our unique aerodynamic, dual powder coated aluminum crossbars will ensure that your rack not only looks great, but last for the life of your truck and beyond.
Features:
  • Mounts in minutes to any truck cap/shell
  • Lightweight (26 lbs.)
  • Load stop-Tie downs easily adjust to suit your cargo
  • High Strength - Load capacity dependent on load capacity of cap/shell
  • Dual powder coated 6000 series aluminum crossbar
Included Items:
  • 2 Dual Powder Coated Aluminum Racks
  • 4 Sliding Aluminum HD Load Stop / Tie Downs with Quick Release Clamping Knobs
  • 2 months later...
  • MIG changed the title to Оборудуем кузов - перевоз длинномеров, палаток, и прочего
