MIG Опубликовано: Октября 10, 2013 Share Опубликовано: Октября 10, 2013 Оригинал - на tundratalk http://www.tundratalk.net/forums/exterior-mods/100571-2007-09-2010-12-grill-conversion.html Нашел Игорь Каменск Tools required, 10mm socket, extension, ratched and trimm removal kit($5 from harbour freigth). You will notice on the pics that I put tape on part of the hood that surround the grill to avoid scratchesReceived my new grill this morning from TRDSparks and decided to go ahead and installed This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Since I was using a plastic trim remmover, I didn't put tape to protect the chrome. This image has been resized. Click this bar to view the full image. Report this image This are the screws under the plastic cover, remove them using the 10mm socket. This image has been resized. Click this bar to view the full image. Report this image Open the hood and remove the 2 screws holding the hood latch. This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Now remove all 10 screws holding the grill This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image put them on a safe place This image has been resized. Click this bar to view the full image. Report this image There are 2 clips on the side of the grill that need to be remove in order to remove the grill. Mine were so old that they just snap broken. No pics of removal. But no worries. The new grill come with new clips. Now just remover the old grill. Now remove the brackets that hold the grill This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Push the tabs in on the clip to remove bracket This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Your hood will look like this now. This image has been resized. Click this bar to view the full image. Report this image Now remove the old plastic nuts that help hold the grill with the screws This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Now install the new grill holders This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Now install the new brackets. The brackets come with new holding tabs This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Make sure that you clean the hood and take all the stickers on the brackets. You can see that the new brackets are smaller so they weigth less, less dirt on the hood shaves weigth also, so this mod will guarantee more MPG and faster times at the track This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Now all is left is, snap the new grill in place and bolt everything back. This mod is a 1 out of 5 in difficulty. Which means that even TRD-X can do itFinal resultsBefore This image has been resized. Click this bar to view the full image. Report this image After This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image This image has been resized. Click this bar to view the full image. Report this image Ссылка на комментарий Поделиться на других сайтах More sharing options...
Максим Симонов Опубликовано: Октября 10, 2013 Share Опубликовано: Октября 10, 2013 ...осталось только найти способ замены на решетку 2014 модельного года :-) .... Ссылка на комментарий Поделиться на других сайтах More sharing options...
Игорь Каменск Опубликовано: Октября 10, 2013 Share Опубликовано: Октября 10, 2013 Не вкорячить ее, при всем желании. Ссылка на комментарий Поделиться на других сайтах More sharing options...
