Djon35 Posted July 19, 2013 Share Posted July 19, 2013 Всем привет,ошибка Р 0705, что делать,подскажите ? Link to comment Share on other sites More sharing options...
MIG Posted July 19, 2013 Share Posted July 19, 2013 Всем привет,ошибка Р 0705, что делать,подскажите ? смогу ответить через час-полтора Link to comment Share on other sites More sharing options...
Игорь Каменск Posted July 19, 2013 Share Posted July 19, 2013 Тож интересно. Это ведь на коробас ошибка? Мож разъем просто глючит? Link to comment Share on other sites More sharing options...
MIG Posted July 19, 2013 Share Posted July 19, 2013 Всем привет,ошибка Р 0705, что делать,подскажите ? ну в общем такDTC NO.P0705 DTC DETECTION CONDITIONWhen one of following conditions is met:(A) Any 2 or more of the following signals are ON simultaneously (2 trip detection logic)P input signal is ONN input signal is ONR input signal is OND input signal is ON(B) Any 2 or more of the following signals are ON simultaneously (2 trip detection logic)NSW input signal is ONR input signal is OND input signal is ON© When any of following conditions is met for 2.0 sec. or more in the S position (2 trip detection logic)NSW input signal is ONP input signal is ONN input signal is ONR input signal is ON(D) All switches are OFF simultaneously for P, R, N and D positions (2 trip detection logic) TROUBLE AREAOpen or short in park/neutral position switch circuitPark/neutral position switchECM Что с этим делать - вот A750F AUTOMATIC TRANSMISSION: AUTOMATIC TRANSMISSION SYSTEM: P0705; Transmission Range Sensor Circuit Malfunction (PRNDL Input); 2007 MY Tundra 11:2006 - .pdfT-SB-0198-08.pdf Link to comment Share on other sites More sharing options...
Djon35 Posted July 19, 2013 Author Share Posted July 19, 2013 Спасибо, а можно как-нибудь по русски и попроще, а то тяжело с английским и со временем разбираться, пока коробка работает нормально, из неисправностей: горит чек, горит 4L, не работают фонари заднего хода и не работает камера заднего вида, а еще замки дверей не открываются, когда рычаг в P, и все, может заменить датчик на коробке и не мучаться с диагностикой всего, у нас стоит 5500, а ? Link to comment Share on other sites More sharing options...
MIG Posted July 19, 2013 Share Posted July 19, 2013 Спасибо, а можно как-нибудь по русски и попроще, а то тяжело с английским и со временем разбираться, пока коробка работает нормально, из неисправностей: горит чек, горит 4L, не работают фонари заднего хода и не работает камера заднего вида, а еще замки дверей не открываются, когда рычаг в P, и все, может заменить датчик на коробке и не мучаться с диагностикой всего, у нас стоит 5500, а ? если это стоит 5500 то надо поменять и забыть ) Ну а если хочется самому - то велкам - инструкций у нас есть) Link to comment Share on other sites More sharing options...
MIG Posted July 19, 2013 Share Posted July 19, 2013 Хотя допускаю что ситуацию это не изменит Link to comment Share on other sites More sharing options...
Игорь Каменск Posted July 19, 2013 Share Posted July 19, 2013 Мож разъем попробовать сначала почистить? Это имхо, я с этим не сталкивался. Link to comment Share on other sites More sharing options...
Djon35 Posted July 19, 2013 Author Share Posted July 19, 2013 Разъем чист как ,,,,,,,,, вот этого и боюсь, что не датчик Link to comment Share on other sites More sharing options...
Игорь Каменск Posted July 19, 2013 Share Posted July 19, 2013 Блин, тож с ангицким никак... MIG, что там? Link to comment Share on other sites More sharing options...
MIG Posted July 19, 2013 Share Posted July 19, 2013 Блин, тож с ангицким никак... MIG, что там? там дока что, куда и как. Идея проста, причин несколько - описано по пунктам что надо выполнить чтобы установить причину Link to comment Share on other sites More sharing options...
Djon35 Posted October 1, 2013 Author Share Posted October 1, 2013 А где находиться второй блок предохранителей? Link to comment Share on other sites More sharing options...
MIG Posted October 1, 2013 Share Posted October 1, 2013 А где находиться второй блок предохранителей? под рулевой колонкой Link to comment Share on other sites More sharing options...
ChyChyNdra Posted October 2, 2013 Share Posted October 2, 2013 А где находиться второй блок предохранителей?уточню... чуть левее, выше площадки для отдыха левой ноги! Link to comment Share on other sites More sharing options...
Djon35 Posted October 3, 2013 Author Share Posted October 3, 2013 Всем спасибо, оказался предохранитель, теперь есть датчик, если кому нужен, пишите. Link to comment Share on other sites More sharing options...
tazprotivvseh Posted May 29, 2014 Share Posted May 29, 2014 А что за датчик где стоит и номер есть ли на нём? Link to comment Share on other sites More sharing options...
